hp 14-dq2039ms tag 5cd137lỵc lên ngắt
B biencodon Guest May 24, 2022 #1 hp 14-dq2039ms tag 5cd137lỵc lên ngắt Attachments W25Q128_20220523_184111 len ngat.BIN 16 MB · Views: 3
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 24, 2022 #2 biencodon said: hp 14-dq2039ms tag 5cd137lỵc lên ngắt Click to expand... File này không theo máy bạn, khả năng Clear ME vẫn tình trạng cũ.
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 24, 2022 #3 File khác: DA0PAHMB8F0 REV: F Attachments 087FD.zip 6.2 MB · Views: 3
B biencodon Guest May 26, 2022 #4 MinhTan said: File khác: DA0PAHMB8F0 REV: F Click to expand... con này ko nhận ổ add ơi
B biencodon Guest May 26, 2022 #5 MinhTan said: File khác: DA0PAHMB8F0 REV: F Click to expand... MinhTan said: File khác: DA0PAHMB8F0 REV: F Click to expand... add con file nao ko cho em xin voi Reactions: MinhTan
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 26, 2022 #6 Đây bạn: 087FD Claer ME Attachments Clear ME.zip 5.8 MB · Views: 9 File New.zip 5.9 MB · Views: 8 Reactions: biencodon
B biencodon Guest May 27, 2022 #7 MinhTan said: Đây bạn: Click to expand... con clame ok roi add oi thanks add
B biencodon Guest May 27, 2022 #8 biencodon said: con clame ok roi add oi ,nhưng bị lâu lên add ơi phai 25-20s mới len Click to expand...
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 27, 2022 #10 BIOS hp 14-dq2039ms DA0PAHMB8F0 REV: F089BB Clear ME Attachments Clear ME.zip 5.8 MB · Views: 1 File new.zip 6 MB · Views: 3
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 27, 2022 #11 BIOS hp 14-dq2039ms DA0PAHMB8F0 REV: F087FE Clear ME Attachments Clear ME.zip 5.8 MB · Views: 3 File new.zip 5.9 MB · Views: 7
B biencodon Guest May 27, 2022 #12 MinhTan said: File new lên nhanh không bạn? View attachment 2758 Click to expand... file new lên nhanh nhưng vẫn bị ngắt add ơi
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 27, 2022 #13 biencodon said: file new lên nhanh nhưng vẫn bị ngắt add ơi Click to expand... File new hãng vẫn tắt, có thể máy lỗi phần cứng rồi. Chép thử 2 bản còn lại xem sao bạn. Reactions: biencodon
B biencodon Guest May 27, 2022 #14 MinhTan said: File new hãng vẫn tắt, có thể máy lỗi phần cứng rồi. Chép thử 2 bản còn lại xem sao bạn. Click to expand... file này chạy ok mỗi lỗi lên chậm. Attachments 15-20s mới lên chạy ok.bin 16 MB · Views: 2
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 27, 2022 #15 biencodon said: file này chạy ok mỗi lỗi lên chậm. Click to expand... Dòng này có 3 bản BIOS, 2 bản file new còn lại sẽ có bản lên nhanh chứ bạn. Vì máy bạn mất file gốc nên không xác định chính xác chạy bản nào.
B biencodon Guest May 28, 2022 #16 MinhTan said: Dòng này có 3 bản BIOS, 2 bản file new còn lại sẽ có bản lên nhanh chứ bạn. Vì máy bạn mất file gốc nên không xác định chính xác chạy bản nào. Click to expand... file là file gốc mà add . Attachments W25Q128_20220523_184111 len ngat.BIN 16 MB · Views: 1
MinhTan Moderator Supporter Oct 25, 2021 2,412 722 May 28, 2022 #17 biencodon said: file là file gốc mà add . Click to expand... Chỉ 1 trong 2 file này Attachments Me_build.zip 5.9 MB · Views: 1 BIOS_build.zip 6.1 MB · Views: 1
